Forum: Music discussion
Topic: trying to achieve a certain effect, help please
jon1988Home userMember since 2005
i am tryin to achieve a certain effect but am having trouble and is a little hard to explain in writing. right...
when i create a loop i can use the shift dial to move it back or forward and that loop moves but in the same length, is there a way i can do it so that only the end of the loop moves? so that i could make the end of the loop come as close as i want to the beginin of the loop whilst the begining stays the same.
geposted Tue 29 Jul 08 @ 1:01 pm
PFD50PRO InfinityMember since 2007
Use software like audacity to cut the loop length (permanent) or use a 1 bar, 2 bar loop instead of a 4
geposted Wed 30 Jul 08 @ 10:58 am
ElopezPRO InfinityMember since 2003
I just reinstall Atomixmp3 on my laptop. I am a registered user. How can I get the full version again? I left numerous messages with support - but to no avail. Please help
geposted Thu 31 Jul 08 @ 10:42 am
Goto the "Products/Software updates" on this site and as you are logged into the forum you will be shown your registration/serial
geposted Fri 01 Aug 08 @ 1:10 am
