I've tried for the last couple of weeks to connect to the radio server but always get "server error." before I was using my HP but I had to send it to the manufacture to get it fix and I'm not going to have for another week.
I've followed all the instructions on the settings and still no answer.
I'm using:
MacBook Pro OS X
2.6 GHz Intell Core Duo
4 GB 667 MHz DDR2 SDRAM
Cue 5.0.7 Mac
Total Control
DJ iO
If anyone has any suggestion please advise....
your boy LoS
I'm using:
MacBook Pro OS X
Cue 5.0.7 Mac
Total Control
DJ iO
your boy LoS
geposted Thu 31 Jul 08 @ 10:18 am
Hey there quick questions for you.
What server are you trying to connect to the VDJ one?
Does it work if you choose local server mode or is this blocked too?
Have you bypassed your router?
Best Regards
Simon Bangs
Computer DJ/VJ product Specialist.
Numark Alesis Europe
Best Regards
Simon Bangs
geposted Sat 02 Aug 08 @ 4:02 pm
Well I haven't tried it, will I have to do another beta test for the mac?
No I have'nt bypass the router but will do so
thanks bro
thanks bro
geposted Mon 04 Aug 08 @ 7:22 pm
