Ok ....So I have vdj 5.1. and its all koo perfect program... anyways wen i use my friends program vdj it doesnt do this, wen i play too songs one is looping and the other is playing, I sync the one that am gonna loop offcourse...and i beat match them so they wont b off ...the one that is looping for some reason even though their both say bpm 120... the one thats looping starts to jump out of beat.....it wont stay on beat with the other song....but if its not looping...it will stay on beat and matched up with the other...never does this on my friends. I know it has to do something with settings....but can some one help me on this please......THANX
geposted Thu 31 Jul 08 @ 10:56 am
Could be that the loop isn't set correctly. Kinda like the start point isn't exactly set on the 1 or the out point isn't set where it should be. If you're using smart loop, it bases it's loop points off what VDJ believes the BPM is. So, even if you set beat match, if VDJ thinks one track is 120 BPM, but it's really 125 it won't set the points correctly. Try to manually set the loop points and see if that helps.
geposted Thu 31 Jul 08 @ 2:42 pm
