Hi,
How do I set the configuration to use both sound outputs on the Denon DNS-HS5500? I have the Denon attached
to my PC via USB and both outputs on the Denon are attached to a mixing board. Currently I am getting both A&B channels of VDJ playing through the A channel of the Denon.
Thanks,
Taipanic
Tarpon Springs, FL
Thanks,
Taipanic
Tarpon Springs, FL
geposted Fri 01 Aug 08 @ 3:15 pm
you may need to check the sound card settings in the VDJ config and assign accordingly. That is a guess as I don't know squat about the DN-HS5500
geposted Fri 01 Aug 08 @ 3:49 pm
go to config/remote and select the 5500 icon.thats it you're done.
connect output to the mixer as normal i.e deck one to line one..deck 2 to line 2
good luck
good luck
geposted Fri 01 Aug 08 @ 6:25 pm
That's what I've done and it is putting both outputs through the deck one output. Using the 5500 in it's normal mode (Non MIDI/VDJ) puts deck one to output one and deck two to output two like it is supposed to.
Thanks,
Taipanic
Thanks,
Taipanic
geposted Fri 01 Aug 08 @ 9:50 pm
I had a similar thing happen tonight, but I think it was because I did not have the asio drivers from denon installed.
geposted Sat 02 Aug 08 @ 3:54 am
I got to work fine for me tonight. Make sure the denon asio drivers are installed, select asio on the sound setup and then select the 5500. You have to make sure the output is set to external mixer. It took me sometime to figure out, but I did. It worked perfect for me for 5 hours tonight.
geposted Sun 03 Aug 08 @ 4:55 am
Reinstalling the Denon ASIO drivers did the trick. I can now use both soundcards but I have been getting a lot of crashes and disconnects from the controller. I am going to create a new profile on my laptop to disable all of the extra Vista junk running in the background.
How vital are the firmware updates? I haven't done any yet as this controller is a loaner until my new one gets delivered. Anyone else having issues? Any advice?
Thanks,
Taipanic
Thanks,
Taipanic
geposted Wed 06 Aug 08 @ 5:26 am
I would def make sure you update the firmware.
geposted Wed 06 Aug 08 @ 2:38 pm
