I'm trying to get version 5.0 working with the new hercules controller. I followed other threads on this forum and sorted out the sound problem, but getting the controller to sync with the software seems a different issue. I'm using Vista o/s and all drivers are up to date. Any help would be appreciated, thanks.
geposted Sat 02 Aug 08 @ 9:07 am
And you are using the DJC Edition that came with the RMX ? Or what version are you using ? RMX was not compatible before v5.0.7
geposted Sat 02 Aug 08 @ 10:45 am
The DJC edition worked fine, but as im trying the v5 only and not v5.0.7 then that must be the cause of the problem. Thanks for the info.
geposted Sat 02 Aug 08 @ 11:01 am
