Ok, so i figured out how to record the video mix with Camtasia, but only some of my existing video clips will show up as video on VDJ. Only the audio is playing. The one I got to work is the same format as the others an AVI file. I have tried converting some to different sizes and other formats all to no avail. Is theere a reason why one clip works and another similar one won't. Please help , i'm getting frustrated, lol.
geposted Thu 07 Aug 08 @ 2:49 am
If you are able to see one avi video, then it is obvious that the avi codec is there. So, you should be able to see all avi files, unless there is an issue with that video. VDJ comes with most codecs installed, so you should not have a problem. What version are you using, and which formats are you trying to use?
geposted Thu 07 Aug 08 @ 3:05 am
