hi,
just changed from maya 44 to sl1 box.
im using a sl1 box as my soundcard with serato vinyls. when i open the config window i use the noisemap setting and when i click autoconfig i get 100% signal BUT the green circular rings go from crisp (as they would in the ssl software) to fuzzy... this makes no sense cuz it says 100%.
also, im still getting pops and cracks every now and then.. but that must have to do with my performance settings (right?)
ive tried pitch sensitivity at 2000 and 0 (doesnt seem to make any difference either way) also, tried to move the silence sliders...
also, in the performances tab, i go from auto, to 2 ms (but 5 ms seems to work best)... i keep safemode and overlock off.
any suggestions? i get perfect signal when i use ssl software so i dont think its a hardware problem.
ps- i also have vdj vinyl that i orderd like a month ago but they do not seem to work well in the v5 mode... only in the v4 mode and the circles look like hell and it goes from 0-100 and everything in between when in this mode. serato vinyls seem to work better with vdj
what the hell?
what the hell?
geposted Thu 07 Aug 08 @ 3:37 pm
