Forum: Old versions
Topic: Including comments in the search
I have the new version (Windows) and when I do a search it doesn't look at comments. I use them to keep track of karaoke singers. Is there a way to get that feature back? Or do I have a database issue?
Thanks.
geposted Fri 08 Aug 08 @ 12:42 am
There is a bullseye next to the search field that tells VDJ what to look at when you type in a search. I would start there. Just tick whatever fields you want to search in ;)
That's right. I had forgotten. Thanks for the help!
No problem; glad you're sorted ;)
