Hey guys
Ive bought a Terratec Producer Phase 26 USB ,installed it and plugged my 2 Timecodes in.
When i try to switch in Virtual DJ setup to 2 Timecodes it tells me "NOT ENOUGH CHANNELS" and only accepts 1 Timecode but the Soundcard got 6x Cinch output (Surround) and 3x Cinch stereo Line-in (1x switch to Phono).
The Soundcard supports Asio and everything else you need for Virtual DJ
What could be the problem and anybody can help me?
thanks alot
thanks alot
geposted Fri 08 Aug 08 @ 8:30 am
A quick Google search shows that this card only has two inputs and six outputs. You need a card with at least 4 inputs and 4 outputs.
Quote :
The Terratec PHASE 26 USB has two analog inputs and six outputs, a MIDI interface, a microphone input, and an amplified headphones output
geposted Fri 08 Aug 08 @ 8:50 am
