does anyone know why I'm might not be able to get sound out of my headphones on my rmx
geposted Fri 08 Aug 08 @ 9:40 pm
give us a clue please how you already have it set it up, then we may not be shooting in the dark, and then doubling up what you may already be doing.
other than that have you stuck the jack plug in.
geposted Fri 08 Aug 08 @ 10:24 pm
I plugged my headphones in somewhere else to check them and they work fine. I plug them in either plug ok the rmx turn up the volume and nothing come through them. The cue is definatly on too
geposted Fri 08 Aug 08 @ 11:12 pm
What are your sounds settings? Also, this is pretty basic, but I thought I'd throw it out there just incase... do you have your headphones plugged in to the right hand plug. The left is the mic.
geposted Sat 09 Aug 08 @ 12:27 am
Hey, thanks for your help I need it for a job today. I fixed it. The problem was in the sound settings. You need to have it on mixer and headphones. Thanx for your speedy help!
Walter
Walter
geposted Sat 09 Aug 08 @ 9:28 am
