Hey there,
I use VDJ 3.2 that came with my Hercules console, but I've installed the new 5.2 trial to test before upgrade. I realized in ALL old skins there's a Virtual DJ logo at upper left corner, so I ask: old skins are not compatible with version 5+? Because I don't use the default skin and I want to keep the skin I'm using in the version 3.2 :(
Thanks!
Roger
Thanks!
Roger
geposted Sat 09 Aug 08 @ 4:06 pm
There have been so many changes since 3.2 that I doubt any of those skins would be the least bit compatible with v5 series software, unfortunately. Once you get your pro version license, however, you can take advantage of a bunch of really great skins designed for the newer versions!!
Now, the new version skins might take a bit of getting used to, but once you start fiddling with them, you'll find that there are a host of features at your fingertips.
Have fun with the trial ;)
geposted Sat 09 Aug 08 @ 4:11 pm
