Hi there,
I have an audio 8 sound card, and i'm wondering if i can use this soundcard in combination with the timecoded cd's from the website to work with vritual dj.
Grtz, mdietger.
Grtz, mdietger.
geposted Sun 10 Aug 08 @ 6:51 am
Yes
geposted Sun 10 Aug 08 @ 9:46 am
As long as it's a PC... doesn't work with Mac.
geposted Sun 10 Aug 08 @ 3:21 pm
Huh wut? Audio 8 works with mac too.
geposted Sun 10 Aug 08 @ 5:20 pm
The Audio 8 does work with Mac as a sound card, but the timecode function does not work with the Audio 8 on Mac (the original poster asked about timecode). I'm a Mac user and I own the Audio 8. I tried it and it doesn't work. I also spoke with VDJ support, and they told me it doesn't work with timecode. In ver 5.2 the only thing that works with timecode on a Mac is the Virtual Vinyl interface and the RMX. If you know something I don't about set up, I would appreciate the advice. I'd love to use the Audio 8 with timecode.
geposted Mon 11 Aug 08 @ 1:25 am
Wow didn't know that! Damn i'm not buying a mac now ;)
geposted Mon 11 Aug 08 @ 1:41 pm
