Is there any way to monitor the sample or samples without them playing over the "air" so to say...sometimes the loops just don't match up for beats right?
Any help would be great.
geposted Mon 11 Aug 08 @ 3:31 pm
I have been waiting for this feature since VDJ 3.0.....
geposted Mon 11 Aug 08 @ 6:32 pm
I agree...A way to listen in A or B decks/split.
geposted Tue 12 Aug 08 @ 8:54 am
No not really.....the sample comes out of both channel, stereo.....so ur best bet is to load it up from the sampler folder onto one of the decks and listen to it that way. This won't help hear if its looping on beat, but then again its set up to do that automatically and from all the no. of samples I've played with, none has had syncing problems..
geposted Tue 12 Aug 08 @ 11:00 am
There is a way... if you have an extra channel on your soundcard?
the 3 channel configuration puts the samples on it's own channel. you can then use the cueing features of your external mixer to monitor/cue
the samples without playing them back to your audience..
you can use 2 different soundcards by using ASIO 4 ALL combine 2 sound cards to make one ASIO Driver with multiple channels.
or get a MAYA GIGA USB
Have Fun,
DJ SMG!
Have Fun,
DJ SMG!
geposted Wed 13 Aug 08 @ 8:59 am
That's how I do it. Works well.
geposted Wed 13 Aug 08 @ 2:02 pm
