The right side will be playing, i load up a song on the left, put the needle down and timecode does not pick up. I check the timecode config and it gives me an error that reads "no timecode signal found, please put down a timecode record." Ive switched turntables and the problem did follow which at first made me think it was the turntable but then the problem happened on the opposite side. This is an intermitting problem that may happen after 20 min of play or 3 1/2 HRS of play. Ive boughten new needles but not cartridges. One weekend, I couldnt get timecode to read for 2 days. I use Vinyl. Please give me some input. Has anyone had this problem?
geposted Mon 11 Aug 08 @ 4:51 pm
What soundcard are you using and do you have the most recent drivers?
geposted Mon 11 Aug 08 @ 5:43 pm
