Ok , i was reading the instructions for all the new stuff and the original set up.. I want to network and looked at the kicking tutorial, thanks .. Now I want to know can I hook up different midi keyboards on each computer asign different midi effects to each while still having the system run like a top? I want to set up 4 turntables a dm2 a midi keayboard or two and 4 cd players and mixers. I want to use on the laptop one maya 44 and on the desk top a delta 66 then send it directly to two different mixers that then go to a main mixer that is set the two systems as equals.. Is this posible and what else do i need to know? Also is there a way to set a visual effect to a assigned key through a midi key? This is going to rock. thank god for redbull and timmy hortons to keep me going.. thanks in advance .. stretch
geposted Tue 12 Aug 08 @ 12:15 am
good luck , that sounds complicated......you should be able to set up the 2 separate systems and connect them as one big system via the 2 mixers into one ..... i don't know how well the midi keys may work compared to a dj controller ......
uhh is 4 yer lucky number ??
geposted Tue 12 Aug 08 @ 8:47 am
cool topic name .... i thought you talking about the forum ......
geposted Tue 12 Aug 08 @ 8:58 am
