New controller.. but for Serato Itch
Vestax - 300
http://www.youtube.com/watch?v=SQfLTUlaehk&feature=related
http://www.youtube.com/watch?v=sfaHVmYA5Rg
if only it would work with VDJ
what u think???
Vestax - 300
what u think???
geposted Tue 12 Aug 08 @ 10:06 am
would such a thing be possible.???
. does appear that it has built in sound card as well if i am right
jog wheels look large enough.. to do something with
definitely would be buying this if it was vdj compatible.....
geposted Tue 12 Aug 08 @ 10:49 am
Although it's not mapped for VDJ, I'm pretty sure it would work as a MIDI controller / soundcard combo, and the jogs are touch-sensitive for better scratching. Problem is whether or not you can get those jogs to work in MIDI. It does have a pretty large price tag too (for a controller).
geposted Tue 12 Aug 08 @ 8:40 pm
considering i was trying to get 2 CDJ 400 - and struggling to find the chingy
the vestax...300 would probably have helped... plus... i am now trying to be as light as possible
my current setup.. takes two persons to carry it
geposted Wed 13 Aug 08 @ 12:54 am
This Unit is gonna work with Cue and the NS7. Maybe thats why there is a delay on the update
geposted Wed 13 Aug 08 @ 4:46 pm
It's a great product, but you might want to take a look at the VCI-100 (cheaper and without a soundcard), also supported in VDJ.
I don't doubt the 300 will be supported.
geposted Wed 13 Aug 08 @ 5:08 pm
I just noticed that itch is a 1 to 1 only for vestax 300. the 300 is a better controller than the the 100 because everything is spaced out more so you can play confortable and not have everything cramped up. The 300 is designed to play perfect out of the box without having to worry about any configuration. You have meters on the 300 and you have job wheels to. The 100 is not for Itch.
geposted Wed 13 Aug 08 @ 5:24 pm
Already know that the Vestax-300 is built around Itch.. but it does say midi
Not interested in the Vestax - 100 whatsoever.
What i would really love to see is the Vestax -300 being compatible soon with VDJ
and native too..would really be a good one mon controller i mean...
geposted Wed 13 Aug 08 @ 5:43 pm
