i can\'t get the timecode to auto config...here\'s the set-up:
technic 1210\'s -inputs 1/2
pass thru 1/2- vestax pmc 06 phono 1/2
o/put 1/2 - vestax line 1/2
numark s/card are switch to phono
program recognizes the s/card and set-up is:
inputs-timecodes
o/puts-ext mixer
s/card-virtual vinyl...
i go to auto config while t/code vinyl are playing and its at zero w/red light...however, in the program\'s view the t/tables both spin and recognizes when i stop and start the t/code vinyl.
is there something i am not doing right? or missing?
could it be my computers soundcard?
inputs-timecodes
o/puts-ext mixer
geposted Wed 13 Aug 08 @ 12:32 am
You need to contact Numark about your box. It sounds like the box may have an issue. May need to add external power to the box.
geposted Fri 15 Aug 08 @ 11:07 am
will do, thanks for the response
geposted Fri 15 Aug 08 @ 5:22 pm
