VDJ Pro 5.2 doesn't show the bitrate of all my MP3s.
The file-details are: Format: 0kbps, 44100 Hz
What can i do to see the bitrate? All files have been bpm-scanned.
Greetz spltunes
Greetz spltunes
geposted Thu 14 Aug 08 @ 3:43 am
To me this function works good in version 5.2
What was your previous version installed on your pc?
geposted Thu 14 Aug 08 @ 5:05 am
Normally it only shows bitrate when the song has actually been played, not just analysed. Play a few songs: do you see the correct bitrate now?
geposted Thu 14 Aug 08 @ 5:12 am
Where can I enable or see this bitrate info? Is it part of the file explorer in the bottom half of VDJ? Is it a new 5.2 feature?
geposted Thu 14 Aug 08 @ 8:20 am
Right Click on the browser and then you can activate the column.
After playing any files the Bitrate is also not shown.
You should know it's a Mac-Version 5.2.
geposted Thu 14 Aug 08 @ 8:31 am
Nobody has an idea?
geposted Sun 17 Aug 08 @ 9:22 am
And are they VBR or CBR files ?
geposted Sun 17 Aug 08 @ 9:56 am
Both, cbr and vbr.
geposted Sun 17 Aug 08 @ 11:31 am
spltunes wrote :
Nobody has an idea?
When you open them up in Itunes (or what ever you mac people use to play music) does the correct bit rate show up then?
geposted Mon 18 Aug 08 @ 11:04 am
