Is it possible to skip through a track seamlessly without stopping it or effecting it in any way?
geposted Thu 14 Aug 08 @ 3:32 pm
What do you mean skip through a track? Can you be more descriptive please?
geposted Thu 14 Aug 08 @ 3:35 pm
yeah mon... u have to be more specific
geposted Thu 14 Aug 08 @ 4:53 pm
just say your tracks playing near the middle, and you want to move jump closer to the end of the track. Without stopping, pausing or skiping through, can you move forward to that part in the track?
geposted Thu 14 Aug 08 @ 5:17 pm
Yes, it can be done but it might jump. What I would do if I were you is load the song on the deck not playing and match beats and BPMs and transition to a later part of the song.....
geposted Thu 14 Aug 08 @ 5:20 pm
As above, you can do it with a hot cue, but it's not ideal. A more reliable way as TearEmUp says - clone deck/load onto other deck.
geposted Thu 14 Aug 08 @ 7:31 pm
yeah... adding a clone deck shortcut key can work wonders mon.... luck for me i did
Have issues with controls on deck 1 .... deck 1 just not going back,to the cue point at all using TCCDs. Stutters either
so i basically use deck 2 to load my songs, loops scratches the works, ..... when i am finished etc... i clone load it to deck1 and just move the fader across, and load next song on same deck 2
Funny though i installed 5.2 few days ago... did a test a couple of times..... hoping I am not wrong here but... my deck 1 seems to be acting perfectly ok... now... will test again 2mro.. just hope it was not a fluke
geposted Thu 14 Aug 08 @ 7:40 pm
Just create a few keyboard shortcuts with function skip_beat (turntable section),
and use values 32, 64, 128, depends on how far you want to skip. Using minus [ - ] sign
in value causes the track to jump backwards for the same amount.
geposted Fri 15 Aug 08 @ 12:25 am
X-ellent exon mobile, those profits you made were out of this world.....j/k......Frankim....u probably have the part that you want to skip to in mind, so the best option would be to have gone through your tracks before hand and set up cue points to which you can jump to on beat whenever you desire, next would be the clone deck option, and third would be to jump blindly using the skip beat function.......
geposted Fri 15 Aug 08 @ 1:51 am
