Hi,
I just got my Maya44 usb and I'm trying to get everything set up. I was able to set the left turntable but the right for some reason will not set. I still says silent. I checked the settings on the mixer for both channels and set them exactly the same. I'm also getting a little feedback. Anyone know how to fix these problems?
geposted Thu 14 Aug 08 @ 6:48 pm
Check your MAYA control panel.
Monitors should be muted, inputs should be about 50-60% and output 100%.
geposted Sat 16 Aug 08 @ 5:38 am
hope you don't have it on a usb hub
geposted Sat 16 Aug 08 @ 1:01 pm
