Hi,
I know its a stupid question but how do I install the mapper for the vci-100? i have downloaded and & have the xml file but don't know what to do with it!
I am currenty using version 5.0.7, I have had to downgrade from 5.2 as for some reason the bpms have gone all wrong since upgraded and nothing seems to match anymore.
geposted Fri 15 Aug 08 @ 1:50 pm
not too sure about the xml file, the only way i know of that can load xml files for control is on the general midi option in remote control section of configuration. i guess in the older version of vdj theres no native support for the vci 100 so general midi would be the only way to control it. in v 5.2 though it has native support so i dont think the xml file is necessary.
also in v5.2 you will need to re-analyse your tracks as the beat engine has changed.
geposted Sun 17 Aug 08 @ 9:51 am
The XML file is a MIDI map, so just go Config>Remote Control->Right Click "General MIDI"->Config and click "Load". This will import the settings from the XML file.
Regards,
Scott
Regards,
Scott
geposted Mon 18 Aug 08 @ 9:51 am
