Topic: Virtual Vinyl only playing one side?
Hi I started to use the vinyl for virtual vinyl but it seems that I'll play one track on one table but then the other doesn't play . Weird thing is if I hit an effect like the siren I can hear it on my channel so I know it's not an audio issue . anyone know what this is about ?
the track loads and looks like it's playing but no sound comes out but if I hit the fx on the same player it sounds fine happens on either or player when it happens .
also with no successful help from numark technical support I tried hooking up EXACTLY how the instructions say and to no success I find out the vinyl only works out of auxillary channels and not Phono. anyone know why ? I tried switching line inputs- grounds - exct
when I leave it on phono I hear the timecode sound on the phono channels but if I switch to auxillary it sounds fine so there's no problem with mixer/numark box/exct
Is there anything in the preferences I don't know about ?
I am using a Urei 1620 LE rotary Mixer
Mac osx 5.2.
Macbook Pro with plenty of ram
Virtual Vinyl ( Latest Update )
Thanks
geposted Fri 15 Aug 08 @ 2:59 pm
