I'm on a mac and am having troubles with virtual dj on full screen. i have put it on full screen, it dosent quite look right, i cant access any of the menu bar at the top and i can't now get it off of full screen. is there a keybord shortcut i could use or something, please help thanks.
geposted Mon 18 Aug 08 @ 3:48 pm
what version are you using? and what skin are you using?
geposted Mon 18 Aug 08 @ 7:37 pm
Yes what version are u using? It be better u registered ur license in ur profile.
geposted Tue 19 Aug 08 @ 3:26 am
two ways, esc/ctrl/alt or you can use ctrl/alt/delete will get you out of that so you can then reboot vdj.
geposted Tue 19 Aug 08 @ 3:40 am
