Hey there. Basically what the title says. VDJ automatically gets the BPM for you btu I want to know how to overwrite this with mixmeisters BPM calculation. I find whenever I have a perfect mix, & I want to loop in vdj my mix start to go off & I believe VDJ calculates the loop length from the BPM.
Thanks for any help
Thanks for any help
geposted Tue 19 Aug 08 @ 6:16 pm
as long as everything has been scanned and tagged in mixmeister, go to the folder of your choice while in vdj right click and choose re scan for tags, should work.
geposted Tue 19 Aug 08 @ 6:27 pm
The BPM engine in VirtualDJ 5.2 is better than Mixmeister. And are you using Sync with the loops and loop/sync'ng both tracks ?
no way!
geposted Wed 20 Aug 08 @ 6:25 pm
I think i have to agree here... it does seem to be better in vdj 5.2
geposted Wed 20 Aug 08 @ 6:45 pm
Wasnt there an issue with 5.2 and RMX? I would upgrade but dont need any problems lol.
geposted Wed 20 Aug 08 @ 8:01 pm
