Hello,
I recently bought virtual dj and I feel like a moron. Which shortcut would I use to play the next song in a playlist? I feel like I've tried all of the obvious ones and it doesn't work. Most of them just loaded the song in the other turntable instead of playing it.
Thanks,
Nate
Thanks,
Nate
geposted Tue 19 Aug 08 @ 7:09 pm
I'm sure this is pretty easy. If anyone could help that would be great. I bought the program to use at my wedding.
geposted Sun 24 Aug 08 @ 7:53 pm
Use a keboard short cut .... assign "MIX" to the key of your choice. I use the + key because it's BIG. Makes it easy to find in a hurry with bad lighting and 4 drunks demanding I play LOVE SHACK :^(
If you bought VDJ you should REGISTER it and join the family.
geposted Sun 24 Aug 08 @ 8:04 pm
