Could you share the script please??
Huey
Huey
geposted Wed 13 Jul 11 @ 8:15 pm
Sure, just substitute your clipbank names to correspond with what you have in my example....
video_fx_select "ClipBank hip hop" & video_fx_button 1 & video_fx & video_fx_select "ClipBank hip hop_random" & video_fx
Good Luck,
Joey...
Good Luck,
Joey...
geposted Wed 13 Jul 11 @ 8:34 pm
Need some help with this...
The only thing I have missing is the ability to turn the effects off when the same shotcut is triggered the second time after it's active...
Is there a script to do this..?
Where in a script would you place it...?
Thanks...
Thanks...
geposted Wed 13 Jul 11 @ 8:54 pm
So I take it the Sonquic Misspelled i know but the effects, are not availale for mac book users???? Please help???? thanks dj jeannette
geposted Wed 03 Aug 11 @ 12:07 am
Wrong thread, but no, Windows only for Sonique.
geposted Wed 03 Aug 11 @ 5:16 am
Hi Scott, is there a script that can turn off a shortcut when pressed a second time?
Thanks,
Joey...
Thanks,
Joey...
geposted Wed 03 Aug 11 @ 8:24 am
I'm not sure what you mean?
geposted Wed 03 Aug 11 @ 9:56 am
A script like this: video_fx_select "ClipBank hip hop" & video_fx_button 1 & video_fx & video_fx_select "ClipBank hip hop_random" & video_fx
If I press the shortcut keys a 2nd time for the above script it will turn that script off or any part off the script if possible..
Thanks,
Joey....
Thanks,
Joey....
geposted Wed 03 Aug 11 @ 11:37 am
not sure what you want to do with it Joey, but you can use this simple variable as a basis for an on/off switch...
is the effect on ? turn it off : turn it on
but thinking back to erics post a couple of weeks ago, I couldn't figure out a way to query if an fx is on or off
geposted Wed 03 Aug 11 @ 12:16 pm
Just started using Clipbank after using Slideshow (another SBDJ plug) for so long on audio only.
I have everything running, but am a little miffed that I may/will forget to activate the randomiser at the beginning of the night. Would a version that was made for the OTHER folder, remove the requirement of having to activate randomiser every load?
geposted Mon 24 Oct 11 @ 9:29 am
Yes. Yes it would. Good call.
geposted Mon 24 Oct 11 @ 9:54 am
Hi scott,
Can you make a " Folder Randomiser" option or plugin or something that would function that way, a Set It And Forgrt It option....
Thanks,
Joey...
Thanks,
Joey...
geposted Mon 24 Oct 11 @ 11:16 am
I don't have the spare time required for that at present I'm afraid.
geposted Mon 24 Oct 11 @ 1:13 pm
All good, when you have a moment. =)
geposted Mon 24 Oct 11 @ 3:16 pm
I was referring to Joey's request - it's a big undertaking to get it right!
geposted Mon 24 Oct 11 @ 3:39 pm
Thanks for the reply scott, Hope things are moving in the right direction yeah....
Joey...
Joey...
geposted Mon 24 Oct 11 @ 5:32 pm
**Gets back in box** =)
geposted Tue 25 Oct 11 @ 9:27 am
I am trying to use CLIPBANK RANDOM on a MAC (lion) with VDJ 7.0.5, I can use clipbank plugin with no problems, I have loaded 12 clips, and everything works fine.... I select clip 1 and it plays, but when I click and activate CLIPBANK RANDOM, nothing changes on the video output, the clip bank random plugin says its changing clips every 5 seconds as I configured it, but the video remains the same (clip1), the blue box (focus) remains on clip1 also, if I select another clip manually then the video changes... but clip bank randomizer doesn't seem to be changing the clips, is there anything I am missing?
thanks in advance
thanks in advance
geposted Thu 27 Oct 11 @ 3:10 am
It could be you haven't got the randomizer teamed up with your clipbank selection name... as don't have a Mac I could be totally wrong though, have a look at this and see if it helps you....
geposted Thu 27 Oct 11 @ 5:47 am
Thanks Tayla, I only have one clipbank.bundle and one ClipBank_Random.bundle ... I tried creating a second bank clipbank2.bundle and one ClipBank2_Random.bundle and still no effect.... the randomizer appears to be changing the selection but the video is the same unless I click on a different clip...
Maybe the plugin is not finished for the mac ? can anyone confirm that it works under Lion ?
thanks again everyone
geposted Thu 27 Oct 11 @ 7:40 pm
