just want to find out is there anyone useing VDJ vista ultimate 64-bit?
geposted Wed 20 Aug 08 @ 4:59 pm
I use Win XP 64 pro. At least 50% faster than the 32 bit edition (loading software, searching files, etc). Im very happy with. My HC-4500 works flawless too with XP64. I guess its the same for vista 64 (compatibility), but I doubt that the performance will be the same VS XP.
geposted Wed 20 Aug 08 @ 5:27 pm
ok cool but vista ultimate is why butter then the home version so i think ppl get most of thie problem with the home version
geposted Wed 20 Aug 08 @ 5:53 pm
i install vista 64bit but just can't get my BCD3000 to work in the 64bit version found out why If you value the benefits and advantages of switching and embracing 64-bit Windows Vista, here’s a few considerations to ponder before making the move to install x64 Windows Vista:
64-bit device drivers may not be available for one or more devices in the computer.
Device drivers must be digitally signed.
32-bit device drivers are not supported.
32-bit programs may not be fully compatible with a 64-bit operating system.
It may be difficult to locate programs that are written specifically for a 64-bit operating system.
Not all hardware devices may be compatible with a 64-bit version of Windows Vista.
geposted Thu 21 Aug 08 @ 12:51 am
Virtual DJ runs fine on 64bit Vista Ultimate. I have had it running for over a year and no problems. However just make sure you can get 64bit drivers for all your hardware.
geposted Fri 22 Aug 08 @ 9:03 pm
yeah could not get my BCD3000 to work in vista 64bit behringer said they coming out with vista driver but did not say if it's for 64bit
geposted Sat 23 Aug 08 @ 1:19 am
