As i have come to understand, there seems to be a problem with songs that are tagged in iTunes. When i try to to load them, i just get an errormessage.
I tried to tag them with a id3-tagging program to see if that could take care of my problem. Sadly, it did'nt. So now im asking you guys! Have u managed
to get "error-tracks" to work? Its a bit anoying that i cant play alot of the music i would like to play :(
geposted Sun 24 Aug 08 @ 10:57 am
Hi Apu, what version of VDJ u using? I can use tracks directly from itunes library in the browser, no error. Also if u purchase the program, do registered it in your profile. Thanks;)
geposted Sun 24 Aug 08 @ 11:25 am
I've had the same problem. Protected files in iTunes will not play in virtual dj. Sure, you can play music out of your itunes library but you can only play songs that aren't encoded by apple protection. I just burn all my itunes music to cds and reimport them. It takes some time and money but i really think it's the only way around this problem.
geposted Mon 25 Aug 08 @ 9:56 am
Just download a program called "Switch" for Mac, it will convert your purchased iTunes songs to whatever format you choose and you'll save yourself a lot of time and money in blank CDR's.
geposted Mon 25 Aug 08 @ 3:40 pm
