does that work with virtual dj if so how can i get it to work?
please reply and help me!!!
geposted Mon 25 Aug 08 @ 11:15 am
depends what version your using if your using (i think! correct me if im wrong some1!) virtual dj 5.0 or later only the mark2 hurcles dj consoe is nativly suported, if your using lower than 5.0 then it should surport it. if it doesnt work though you can configue it as a midi input and manually configure each button and slider and jog weel but it does take quite a while! or someone else might have the xml file with the config already on it, rember to save the file though!
geposted Wed 27 Aug 08 @ 12:17 pm
My MK1 works ok using 5.2 and just clicking on the hercules console icon
geposted Thu 28 Aug 08 @ 8:45 pm
