I don't know if im doing something wrong but when I mark a cue point in deck 1 it shows. Now I load the same track to deck 2 and the cue point is not there. I have to mark the cue point in deck 2 to match deck 1. Is there any way to get the cue on both decks to match after marking the cue once on a deck. I know in serato I mark a cue and its on both decks same spot.
geposted Wed 27 Aug 08 @ 8:23 am
You mark the cue point once and it will show in both decks. So don't know what you are doing different. Are you absolutely sure you are loading the same track to both decks? And not a different track from a different location?
geposted Wed 27 Aug 08 @ 8:25 am
I will check again when I get home, but it is the same track and its only showing cue point on one deck. But I will check it out again. Perhaps because im using a mac
geposted Wed 27 Aug 08 @ 9:59 am
