Hello fellow dj's
I Know that this has probably been answered but i can t find it in the forum or on wiki
How do you ripp Music DVD's to the computer what format does VDJ use? What is the best software to do it?
Thanks in advance
DJ MikeD
Thanks in advance
DJ MikeD
geposted Fri 29 Aug 08 @ 11:38 am
smartripper is a great program to use. I use it for all my videos and always gives a solid performance. If you search a little harder in the forums for "smartripper" you'll find the website to download it (for free!) and the instructions to calibrate the program properly. This program rips into .VOB files which produces 200 MB to 300 MB videos. great quality! Make sure you pick up a terabyte drive....good quality videos take up a lot of space!
geposted Fri 29 Aug 08 @ 11:45 am
We really need to start a Wiki on this.. :)
geposted Fri 29 Aug 08 @ 1:39 pm
yea, good idea. A tutorial of sorts...
geposted Sat 30 Aug 08 @ 3:20 pm
that is an excelllent idea, lots of misinfo out there that could be cleared up
geposted Sun 31 Aug 08 @ 2:31 pm
i made this last December as you can see and i think i might just update it, i tried to put it on wikki with the rest of my blogs but i failed miserably, basically I'm useless, anyway hope this maybe what you are after so i hope it helps. there's other vids in my home page if you want to check them out.
EASIEST DVD RIPPER? (PROBABLY)
Tue 04 Dec 07 @ 1:15 pm
hi everyone
as the title says i hope I'm going to show you one of the easiest & quickest DVD rippers on the market place, if I'm wrong will someone please point me in the right direction.
there are many rippers out there used by members of these forums who have different success rates with them and claims to how easy they are with the user and you all know the brands that get mentioned more than others, plus the endless info you have to read and then go back and re read it.
the software I'm going to show you is found at http://www.avsmedia.com/VideoTools/index.aspx and is on special at $39.95 or roughly £20 as well as ripping it will record from and too any number of file formats, you have everything you need in one package and comes in a "try before you buy version", no need to read through lines of endless instructions take a look at the video clip and see how easy & quick it is...
hi everyone
it took less than four minutes from me starting to make this video to the end to rip and tag two DVD music video tunes
the video clip is not to sharp so if you want a better version just pm me
hope it helps someone...
Tayla
geposted Sun 31 Aug 08 @ 2:55 pm
