So I have some Karaoke I want to zip and I used this program that was not the standard mp3g to zip that you can find on google. It was requested by a VDJ moderator, but when I open the ticket from my email it says it is no longer valid. I have reformatted my windows machine, so I can't find what program I used.
What is the best program to zip up mp3g files? Specifically one that will do the subfolders as well, so you don't have to keep checking it EACH time a subfolder occurs in your Karaoke collection.
Matt
Matt
geposted Fri 29 Aug 08 @ 12:05 pm
Hi Mat
I have been where you are
ok the program you need is here, it not free! but then the best programs arn't ! this program is the best for all compression & decompression of karaoke files mp3+CDG
heres the link
http://www.powerkaraoke.com/src/prod_powercdgburner.php
Power CD+G Burner
Burn CD+G discs on your computer. Save (rip) CD+G tracks to hard disc. Power CD+G Burner is an all-in-one solution to CD+G karaoke disc burning and ripping. It will burn CD+G (BIN, CDG, MP3+G, ZIP, and KMA) songs on most of modern CD-R drives. With Power CD+G Burner you can save CD+G tracks to hard disc (in MP3+G and ZIP formats) and copy CD+G with single mouse click.
This program works and is worth every penny
Hope this help,
Regards
John
heres the link
Power CD+G Burner
Hope this help,
Regards
John
geposted Fri 29 Aug 08 @ 1:01 pm
Pick up this program. The best program I have ever used!
http://www.activeaspsoftware.net/default.aspx?p=downloads
AND IT'S FREE!
regards
AND IT'S FREE!
regards
geposted Fri 29 Aug 08 @ 4:03 pm
MP3+G TOOLZ is what the program is called
geposted Fri 29 Aug 08 @ 4:04 pm
Thanks guys! MP3G Tools was the about and I used! It's free and it works great! I'll check out the ones you guys mentioned though -- that burning program sounds awesome. Cheers guys!
Matt
Matt
geposted Sat 30 Aug 08 @ 11:30 am
