Forum: Music discussion
Topic: What is it called?
pidi5PRO InfinityMember since 2008
During a mix when you hear " You're now in the mix with dj whoever" or something of that effect. What is that called and how or what would I use to create my own "tag".
geposted Mon 01 Sep 08 @ 1:47 am
It's usually called a "Name Drop" or "tag"
You can make them yourself using a DJ mixer, microphone and a Recording/editing software
There are many free ones available - Google is your friend.
You would record your sample, edit, add effects to taste, and then create a MP3 file that can be played in a VDJ deck or in the sample engine
geposted Mon 01 Sep 08 @ 2:18 am
Thanks bro
geposted Mon 01 Sep 08 @ 2:29 am
Some pro companies call it a DJ drop ;)
geposted Mon 01 Sep 08 @ 3:05 am
geposted Mon 01 Sep 08 @ 1:51 pm
Thanks guys
geposted Mon 01 Sep 08 @ 3:35 pm
i like to call it annoying but if you have a mac you can make it in garage band. you can also turn it into a ringtone in garage band.
geposted Mon 15 Sep 08 @ 5:08 pm
