Topic: Clipbank Question
I just started using clipbank for some ambient type videos, and was wondering if it's possible to use the transistion effects? I don't want to just play them all the way through, was hoping I could switch back and forth. Thanks
geposted Wed 03 Sep 08 @ 9:30 pm
taylaPRO InfinityMember since 2007
nope, but soon to be released will be a random clipbank plug in by sbdj (scott) which will bring a new dimension to it, basically it will save you from having to select your next clips, it has a sliding timer for how long you want your sequences to run for, works great for me.
geposted Thu 04 Sep 08 @ 6:03 am
Thanks for the heads up Tayla!
geposted Thu 04 Sep 08 @ 7:29 pm
