I see there is a 5.2.1 version http://www.virtualdj.com/download/updates.html , what is better or fixed?
I hope the Denon 5500 is controlled better.
geposted Thu 04 Sep 08 @ 6:46 pm
5.2.1 was designed to fix some of the controller issues effected by 5.2 in comparison to 5.1, for example the RMX/Hercules issues.
geposted Thu 04 Sep 08 @ 6:53 pm
Hi Jim, these are the fix.
Bug fixes:
-Low-latency scratch on Denon HS5500
-Fixed pitch-bend and button order on DJConsole RMX
-Fixed pitch on DAC2
Anyway you could also look into the wiki and look at the vdj history for any updates info of the new release.
http://www.virtualdj.com/wiki/VirtualDJ_History.html
Regards;)
Bug fixes:
Regards;)
geposted Thu 04 Sep 08 @ 6:54 pm
Hello
I can't see any differeent between the 5.2 and the 5.2.1.... I tryed today to fix my buttons of the remix controler like in the 5.1 version. However the button config. do not work with the 5.2.1 version.
Has anybody a idear or a tip how i can config my rmx buttons??
geposted Fri 05 Sep 08 @ 3:51 am
From: http://www.virtualdj.com/addons/4430/Rmx_Buttons_Configurator.html
Description:
A simple tool to configure the 6+6 custom buttons of the Hercules Dj Console Rmx into Virtual DJ v5.0.7 or v5.1 but NOT in v5.2!
To configure the 6+6 custom buttons into Virtual DJ v5.2 please download the new Hercules RMX skin into the Skins download section.
And 5.2 RMX Skin is here http://www.virtualdj.com/addons/4554/Hercules_RMX_variations.html
Description:
geposted Fri 05 Sep 08 @ 4:01 am
thanks for the guick answer :-)
Thanks for the news about the remix config.
i downloaded the 5.2 skin for the remix controller. with this skin you can only choose between the loop in and loop out. but i only need loop....
i do not understand why vdj no not allowed the remix button config :-( the tool was really nice and it is very important
do you have any other tip.what could help me???
geposted Fri 05 Sep 08 @ 4:06 am
Sorry but for the moment the only way to use "loop" direct shortcut is to use VDJ 5.1 and the Rmx Buttons Configurator.
geposted Fri 05 Sep 08 @ 5:05 am
can you please ask dj cel or an other vdj user to make an mapper for the rmx controller :-) which also works with the 5.2.1 version
i get next week my new pioneer 400 and i want to use the new version :-(((((
geposted Fri 05 Sep 08 @ 5:19 am
Any idea when the "search crash" update is coming out?
geposted Fri 05 Sep 08 @ 7:12 am
Does the latency scratch for the HS5500 mean that the problem with the spinning platter has been fixed?
geposted Fri 05 Sep 08 @ 7:46 am
