HI, I just bought the new version of virtual Dj 5.2 with a vestax VCI-100 midi controller. It has been correctly installed but i'm not able to connect it to virtual DJ only by activating it in the remote control... 1 also use 2 soundcards that are properly installled.
Thanks for helping me, I'm a new user here.
geposted Fri 05 Sep 08 @ 11:24 pm
Please re read your post, as it is a little confusing. I am not sure what you are asking.
geposted Sat 06 Sep 08 @ 1:39 am
Hi, I just bought a Vestax VCI-100 and i wanted to make it work with the new virtual DJ 5.2 who is compatible with the VCI-100. Nut i'm not able to connect it with virtual DJ. Do I have to make something else than just activate the image of the VCI-100 on remote controle options?
Thanks!
Edit: post is more understandable now, sorry!
Thanks!
geposted Sat 06 Sep 08 @ 1:46 am
What happens when you activate the VCI-100 in the remote controll section? Does it turn green?
geposted Sat 06 Sep 08 @ 1:49 am
It would be a good idea to register your software.
geposted Sat 06 Sep 08 @ 1:53 am
