Is this program good for house mixing?
geposted Sun 07 Sep 08 @ 10:20 am
Very much so....most of the Sunday House Heaven DJs on Radio use Mixed in Key...
geposted Sun 07 Sep 08 @ 10:21 am
It's claimed that VDJ has a more accurate detection though..
geposted Sun 07 Sep 08 @ 11:13 am
We dont ;)
We used mixmeister before, we use VDJ now :)
geposted Sun 07 Sep 08 @ 11:16 am
By program I assumed the question was Camalot..not MixMeister.. ;)
geposted Sun 07 Sep 08 @ 11:17 am
Mixed In Key is a program ;)
Both Virtual DJ, Mixmeister and Mixed In Key shows Camelot key codes :)
geposted Sun 07 Sep 08 @ 11:18 am
How do you know the keys of songs with VDJ??
geposted Sun 07 Sep 08 @ 12:02 pm
Right click on the cross bar in the browser in VDJ...and select either, or both, Camalot and/or Key....that will allow the key, or Camalot code, to show depending on what skin you are using
If you are using a skin designed for 5.1 or later you should be fine....
geposted Sun 07 Sep 08 @ 12:05 pm
