Topic: .swf files in Clipbank?
Well, i've tried it. Flash clips can't be used in the clipbank. How can i use flash clips with VDJ?
geposted Wed 10 Sep 08 @ 9:05 am
convert over to avi or mpg2
That kinda sucks as our entire video crew uses .swf files if we just use projectors and a hardware video mixtable... Including me.
There must be a way we can play .swf files in VDJ.
i've just checked the codecs (config > codecs) you maybe able to add that particular codec, but to make absolutely certain i would check with cstol or one of the other teamers,
Why are you using swf files?
For use with the clipbank they need to be in mpg, avi (divx, xvid), vob, etc.
Ledwall animations we use are usually in .swf. Also many text animations (premade) are in .swf.
here's another one you may want to look at http://www.magic-video-software.com/mvc.html it will convert upto twenty hours of files in one batch according to there sales pitch, i use this and avs video converter and have converted twenty files in one go, with good results. hope that helps.
Okay that's kindof a workaround. Ok i'll try that. (Check my blog for pics, the week after 25th of octobre)
