I'm a little confused about what VDJ uses when it loads the shortcuts. I see that initially under MY DOCUMENTS, there is a SHORTCUTS.XML file, as well as a SHORTCUTS_DEFAULT.XML file. If I'm spending the time to add a lot of macros and custom shortcuts, which one should I be loading it to? And which one is recalled when I start the program?
The reason I ask is that some keyboard shortcuts that I had already programmed in the past seemed to have disappeared. I would like to build my shortcut file once, and have that file be the one that is always loaded and used....
Any suggestions? Thank you.
geposted Thu 11 Sep 08 @ 12:05 am
Good question mate ;-)
Honestly i dont know .
Ask the Moderators.
Ask the Moderators.
geposted Thu 11 Sep 08 @ 1:45 am
Shortcuts.xml is the one that is loaded.
The Shortcuts_Default.xml is just one you can load I believe to restore the keyboard shortcuts back to default.
Regards,
Scott
Regards,
Scott
geposted Thu 11 Sep 08 @ 3:16 am
I see. So if I select MERGE, it will always merge the selected XML file with SHORTCUTS.XML?
geposted Thu 11 Sep 08 @ 10:41 am
