I would like to be able to load a vst that applies to master output (post fader), set it, and let it on all night.
Think compressor, expander, maximiser, eq etc ...
An effect that would correct the room or the sound system accoustic.
Possible in a next version ?
Thanks !
Thanks !
geposted Tue 23 Sep 08 @ 3:29 pm
So no one sees this suggestion as something very useful ?
I guess no one is working in heterogeneous environment then... too bad
geposted Mon 29 Sep 08 @ 9:26 pm
Search through Wishes and new features forum and VirtualDJ Plugins, I'm not sure
whether a master channel plugin is possible yet or not, but it's been discussed/requested
many times here.
Regarding correcting the room/sound system acoustics, it's impossible to do any significant
corrections by altering the audio signal. It's possible to compensate slightly for rooms with
more reflections on certain frequencies by adjusting the graphic EQ a bit, but if the
room is not acoustically treated or wrongly treated, don't expect good results.
many times here.
geposted Tue 30 Sep 08 @ 3:03 am
I think this would be a great feature. Adding the software based BBE Sonic Maximizer may not help all acoustical problems but would help to improve sound quality overall. I think it might also be helpful at times to be able to switch between stero & mono out.
Greg
Greg
geposted Mon 03 Nov 08 @ 11:03 am
Thanks !
+1000
Really great feature!!!
Thanks !
+1000
geposted Sat 25 Apr 09 @ 5:58 pm
