How can I switch the serial number on my copy of virtual dj? I accidentally purchased the program twice and have already gotten this corrected and one of the serial numbers cancelled. However, the serial that was cancelled is the one that I had already entered in my account profile to be associated with the program. How can i switch the serial number to the valid one so that I can use virtual dj again?
geposted Thu 24 Jul 03 @ 6:48 pm
You'll probably have to re-install Virtualdj, and use the proper serial number on the first launch.
geposted Thu 24 Jul 03 @ 6:56 pm
Hey DJ Rick... Read his problem again, the problem lies not with in his installation, it is using the good serial, the problem lies within the cancelled serial being used within his VDJ forum account.
My suggestion is to contact customer support, I know they must have an email address, still looking for it myself. But I do know of this page in which should still be able to aid you.
http://www.virtualdj.com/support/ask.html
Hope this helps..
Regards;
Redman247
Hope this helps..
Regards;
Redman247
geposted Thu 24 Jul 03 @ 8:01 pm
DOH! sorry, my bad!
geposted Thu 24 Jul 03 @ 9:54 pm
Rick has answered the good answer, simply uninstall/reinstall the software and enter the correct serial.
If you're computer still say something about incorrect serial, contact us, we will check your account dinamically to unlock the software.
Regards,
Yan-X
Regards,
Yan-X
geposted Sun 27 Jul 03 @ 1:22 pm
northleaf: contact service@virtualdj.com
geposted Mon 28 Jul 03 @ 1:52 am
Thanks! I had to change my online account and login name, but the serial works fine now. Much appreciated...
geposted Mon 28 Jul 03 @ 4:03 am
yes i have checked your account but you forgot to modify the email address to your old account as answered to one of your email.
I have simply modified the old acount and now the system works fine :)
Besides, I have updated the FAQ with question II.4 regarding serial numbers
geposted Mon 28 Jul 03 @ 2:32 pm
