Now You are building the more funtional software for dvjs, i think is time to add more quality, as i elaborate next. . .
1.- Sound Engine & EQ Quality - i think the sound is not good enoghf compared to other softwares (the video/audio source must have quality) and the EQ is so nasty (maybe the Frecuenzy of the knobs are not good tuned)
2.- Master Tempo - Well You Know what im talking about it just dont work (So Granulated, Take A Look To Pionners CDJ 1000 or even Torq, Traktor)
3.- Stability - Crashes Lots of times (i know it changes depending the configuration of every PC but i dont know exacly, wich componets VDJ need to work crash-Free, Directx, .NET etc; Maybe You Can Post Every Single Component You Need To Install to Make VDJ Rock Solid) did i xplain good?
4.- Per-Deck Pitch Range - This Could Be A Good One At Least 4 me, have the chance to change the pitch range on each deck on the fly
5.- More Eye-Caption Transition even if i have to pay for a premiun transition & FX Pack
6.- Audio FX As Aux/Send-RTN or Insert
7.- Better MKV (h264 in general) Support
this are based using the "Best Quality Preset" on the performance panel And Im Using an Xponet Sound Card (And Sounds Great But Others Soft`s audio engines are realy good and VDJ have amazing funtions thats the way i buy it to support his development)
sorry the bad english but is not my language.
geposted Sun 05 Oct 08 @ 11:31 pm
I completely agree with you about the first three points
geposted Mon 06 Oct 08 @ 5:03 pm
1+
geposted Mon 06 Oct 08 @ 9:40 pm
+1
geposted Thu 09 Oct 08 @ 11:32 am
can at least any teamer, respond at the point 3. . .
thanks
thanks
geposted Thu 09 Oct 08 @ 8:37 pm
Teamers never answer to these topic but they analyse each thread and, if they think our suggestions are easily feasible, they are going to implement them.
In my opinion, they are working right now to improve VDJ software
geposted Fri 10 Oct 08 @ 4:23 am
Got to agree about most of this stuff. Although things like EQs can be worked around with VST effects rather than using the vdj EQs. It would be nice to have this basic stuff built in though.
Also a pitch range selector button would be great. On most CD players it's just a single button that toggles between all the modes (8%,12%,20%,100% maybe)
I don't have problems with VDJ crashing, but I don't really use any plugins or inbuilt mixer functions even, just a pair of video decks.
geposted Fri 10 Oct 08 @ 6:46 am
A pitch range selector is already do-able - it's just a skinning thing, some skins already have it.
geposted Fri 10 Oct 08 @ 7:50 am
Thanks, I didn't know that. :-)
geposted Fri 10 Oct 08 @ 6:51 pm
You can also set up MIDI or keyboard shortcuts as well :) As per the OP though, it's global, not per deck.
I think the problems people are having may be down to their settings, you seem to need to have enhanced scratch enabled for master tempo to work in advanced mode :)
geposted Fri 10 Oct 08 @ 8:55 pm
Agreed - as long as your system is quick enough for you to be able to run in advanced mode at a decent performance setting, master tempo sounds fine for me...
geposted Fri 10 Oct 08 @ 11:00 pm
somthing i dont undestad is the parameter in the master tempo field this presets set the complexity in 3 what happend if i change it to 10 and why spatialization is alway 0 ?? in all the presets
thanks.
geposted Sat 11 Oct 08 @ 4:16 am
1. sound engine... it's always getting better. in my opinion it IS good enough. but they keep working on it.
1.b. are you kidding me?? get a dj mixer and change the eq there.
2. master tempo.. we have pitch and we have key.. more like speed and vocal adjustment. but it's there.
3. stability.. YES YES YES. keep working on this.
3.b. performance. FASTER FASTER FASTER. database, search, the whole thing. i've seen this issue on several different computers.
4. per-deck pitch.. sounds good to me.
5. what is "Eye-Caption Transition" ??
6. audio fx.. i thought we already have those.. flanger, etc.
7. what is "MKV" ??
7. what is "MKV" ??
geposted Sun 12 Oct 08 @ 7:23 pm
djkz wrote :
what is "MKV" ??
http://en.wikipedia.org/wiki/Matroska
geposted Mon 13 Oct 08 @ 3:14 am
No...I don't think like that djkz!
If to work in good way with VDJ software an user needs an external mixer, Atomix should sell this software only like LE version with a mixer; this in order to prevent users from using it without any mixer.
As VDJ has sold like an apart element, the right ploy is that VDJ must work with no problem even if the user make use of none external devices
geposted Mon 13 Oct 08 @ 4:26 am
Better Good Looking Transitions
i talking about the behavior, how they work!!!!
geposted Mon 13 Oct 08 @ 8:00 am
