This problem just started last week. I use version 4.2r1 and have problems with auto play. All else works great. When I set up a play list for when I need a rest room break or to visit someone in the crowd (bar break) this crazy problem arises. One song will be playing, next song awaiting on next deck, when song one finishes and the next deck will auto mix. Up to now no problem. The next song on the play list will load onto the first deck and sometimes after that song loads - the number 2 song in the play list will reload onto deck one and the song that is now playing will skip several seconds to minutes into it. Can someone please let me know if I changed some setting by accident. I did add Norton 360 to my laptop last week and that may have done something. I don't use this as dedicated system yet. This problem is not constant but seems to happen to the same songs when it does. This sounds confusing so please let me know if you need any more info. Thanks
geposted Mon 13 Oct 08 @ 9:02 am
Hi, Why don't u try the trial version that u may download here n it work for 20 days and if u have the pro version, do register n upgrade to the latest version. Automix is enhanced n better than in v4.2r1.
Regards;)
Regards;)
geposted Mon 13 Oct 08 @ 9:13 am
Spinna is correct. The auto play was changed in version 5.0 to address the types of issues you described. Download and use the latest trial and see if that suits you better.
geposted Mon 13 Oct 08 @ 9:35 am
