Forum: VirtualDJ Plugins
Topic: New Years countdown plugin - Page: 9
Agreed, it was the biggest crowd/event I have ever worked and you help me make this part flawless. Thank you!
Thanks Scott! Worked perfectly on NYE. I used script in Stage 2 to load my Big Ben Chimes/Peels track onto the non-playing deck - set for 180 seconds before (3 minutes). Countdown was on screen from approximately 6:30pm until 12:15am - flawless :) Thanks again!
Yup I to can say everything about this plugin went perfect!!
Thanks again
No problem guys.
I've just uploaded a slight update which should fix the issue with the GUI being unresponsive after a popup window appears.
I will get the Mac version sorted too, so any other feature requests get them in early :)
word wrap or multiple line text.
if the text or number font size was larger in the previous one then it would put the text on the next line. this one won't do that. can't put LARGE in-in-your-face words that drunks can see up on screen. just single line so far.
I'd like to type in the number for size and placement on the screen.
It's hard making 3 of the 4 stages the same with the little dot, lmao!!
Right click on the X/Y and knobs brings up the adjustment dialog box.
hello there t there a tutorial or a video to explain how to use addons COUNTDOWN I do not understand how the script?
to 5MIN
Thank you for your help.
Hi SBDJ,
I using this plug-in in version 8.2 to me freezes VDJ. Could you advise?
Thank you very much!
soo.. any chance of an updated Countdown plugin? or to even have it back in the plugins/add-ons downloads again?
I've been using the last release of the plugin on the current release of VDJ without issue.
If you still have the old one I would give it a shot and test it out for a bit.
I've been using that last release at the club too for years. and will continue to do so, but the push towards 64bit is coming on still and we wantsss the precioussss!
new 2020 update breaks menu :( Hopefully we can get a fix before New Years!
I don't think so...
not even a 64bit version or some other of its plugins :/
SBDJ Scott leaved VDJ team a long time ago and doesn't have this plugin on its site
And worth, they are no more available to download anymore
the best way ? try to contact and ask him directly
This one May perhaps be scripted using new scheduler
