Forum: VirtualDJ Plugins
Topic: Synq PCM.1 Midi Mapper available!
ciocePRO InfinityMember since 2004
geposted Fri 14 Nov 08 @ 2:19 am
OoopsPRO InfinityMember since 2003
Thx ;=)
Hope to help someone
Other config in few days (video and .... )
Cya
Ooops
Jean-Yves
geposted Fri 14 Nov 08 @ 4:26 pm
Hi all,
Midi Mapper V 1.1 online
= History =
V 1.0
First mapping
V 1.1
CUE better play
Pitch Reset deck1 => [Shift] + [Pitch Lock]
Pitch Reset deck2 => [Shift] + [Pitch Lock]
Master volume => [Master]
Gain down deck1 => [Shift] + [Pitch Bend -]
Gain up deck1 => [Shift] + [Pitch Bend +]
Gain down deck2 => [Shift] + [Pitch Bend -]
Gain up deck2 => [Shift] + [Pitch Bend +]
PFL Listen deck1-deck2 => [CUE MIX]
PFL Volume => [CUE VOL]
Ooops
Jean-Yves
geposted Sat 15 Nov 08 @ 4:14 am
Hello Jean-Yves i'm got a ? can synq pcm 1 midimapper download on other websides im need the mapper im pay numark cue with iron icue controller on www.gadget.dk and this serial nr. will nor work help me
geposted Wed 17 Jun 09 @ 8:48 am
Sorry, mappers are only available to registered licensed users of VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
If you have a license for the full version of Numark Cue, please register it on the following page: http://www.virtualdj.com/users/edit.html
NOTE: If your version of Numark Cue came free with the iCue controller, it will be the LE (Limited Edition) version and does not support the use of any other controllers except for the iCue.
The Synq PCM-1 is natively supported under Vista in VirtualDJ v6 with fully working LED's. Windows XP will also be supported shortly with a firmware and definition update.
MIDI mapping in VirtualDJ/Cue v5 and earlier does not support working LED's.
geposted Wed 17 Jun 09 @ 1:19 pm
now native support for this all in one 19'' controller
geposted Sat 06 Feb 10 @ 3:20 pm
