Forum: Old versions
Topic: VDJ wont show me the BPM of a track
JuliusNHome userMember since 2008
Hi, I'm having a problem with this software. Every time I load a tack, it wont show me the BPM or the elapsed time of the track. I recently moved from my old Numark Cue software to this because I heard that it was better. Can someone help because I would really appreciate it. Thanks
geposted Tue 25 Nov 08 @ 8:55 am
jimmy bPRO InfinityMember since 2007
Are all your files scanned?
geposted Tue 25 Nov 08 @ 8:56 am
Well they could be because I used some of the tracks on Numark but I'm not that sure. Should I scan them?
geposted Tue 25 Nov 08 @ 8:59 am
Yes I would.
With the new BPM engine it will give you the key for that track aswell.
geposted Tue 25 Nov 08 @ 9:14 am
Ok cheers mate, so how do I do that properly.
geposted Tue 25 Nov 08 @ 9:20 am
Got you files up in browser.
Highlight all the files by using Ctrl+A buttons.
Once highlighted do a right click, you should see a option for "Scan for BPM" hit that.
geposted Tue 25 Nov 08 @ 9:25 am
I just had the same ıssue then try what you ve just type here but stıll doesnt show bpm I just scan all of them
geposted Wed 03 Jan 18 @ 7:43 pm
If you're using the LE version then there are some limitations in the browser, compared to the full version.
geposted Wed 03 Jan 18 @ 7:59 pm
