thank you moramax for your work, and a happy new year!
I have testet your plugin today and it works well.
Now i can use the 3 Faders as EQ-Faders :-)))
I saw only one mistake on the standard settings - the sync-buttons are configurated for the wrong deck, but after changing and saving the settings, your plugin doing a great job!!
geposted Thu 01 Jan 09 @ 12:29 pm
Quote :
thank you!! i'll check and ' ll fix it
geposted Thu 01 Jan 09 @ 3:40 pm
Quote :
thank you!!
thats natural
Will you support the effect-buttons too in future versions of your plugin?
geposted Thu 01 Jan 09 @ 11:40 pm
moramax wrote :
i repeat again!
The 6+6 buttons can be customizerd using (only the 6+6 buttons) the slots. With new system i can't use that buttons directly.
(maybe exist an hardest solution, but i can't do it for now)
^^^^^^^Once again Not Possible
geposted Fri 02 Jan 09 @ 12:33 am
Thank you for your answer! Didnt read it before, sorry - my mistake!
geposted Fri 02 Jan 09 @ 5:45 am
thank you all for the reports!;)
geposted Fri 02 Jan 09 @ 7:49 am
Hi MORAMAX,
Will this be available for mac users anytime soon? It looks fantastic, I applaud your work.
Or
Does anyone know how I can map my hercules rmx in virtual dj using a mac?
Thanks guys.
Priscilla
Los Angeles, CA
Or
Thanks guys.
Priscilla
Los Angeles, CA
geposted Mon 19 Jan 09 @ 8:59 pm
Hi,
it's not planned for now. The conversion for mac required a lot of time.
But to map the Hercules rmx you can use the general MIDI function of VirtualDJ.
geposted Tue 20 Jan 09 @ 7:23 am
Hallo everybody I need help
My english is not so good
I would like to download the Rmx Buttons Configurator for my hercules rmx but
Your current licenses do not allow you to download Tools =(
how can i get the RMX Buttons Configurator ???
thanks for help
thanks for help
geposted Sat 06 Jun 09 @ 9:35 am
It's only for PRO user.
geposted Sat 06 Jun 09 @ 11:08 am
