Forum: Old versions
Topic: PC Screen Resolution Problems... - Page: 1
I am a club DJ, but on my nights off I stay on top of my game and come up with new transitions on VDJ on my PC. (Windows XP Home) I am NOT a whiz at the computer, but I'm no dummy.
I try opening my VDJ program and after it asks which skin I would like to use, this alert comes up... "Warning! The skin you are trying to use has a higher resolution than your screen."
Each skin gives me the same alert.
I check the display settings and my screen resolution is set at 800x600. The color quality is 32 bit (highest).
Do i need to go into "256 color mode"? Change my DPI?
My monitor is a brand new 19" Samsung SyncMaster 920NW LCD wide screen. $200 monitor. You can imagine how upset I am with this problem.
Also, are there any other unneeded processes that I can end in the Task Manager to help the performance of my PC? Right now I have 38....while idle. Weird, huh? (many named "svchost.exe") And I have just over a gig of RAM. Should I get more?
Any advice would be GREATLY appreciated!!
Thanks!!
-demize..
geposted Wed 10 Dec 08 @ 11:42 am
You just showed yourself where the problem lies.
Most skin's for VDJ are at least 1024x768, or other 4:3 / widescreen resolutions.
800x600 is an old standard for low resolution monitors, use the resolution that
is native (recommended) for your monitor. It says here that your monitor is
widescreen 19", and specifies the 1440x900 as native resolution.
You might want to learn more about modern display resolution standards on
wikipedia, if interested :)
As above, 800x600 simply isn't high enough a resolution...
K, i got the display problem pretty much resolved.
How about when i drag a song onto side A or B, it takes a few minutes to load up a song. VDJ is the only program running and it still takes a while. The music files are mp3 and they are all good with quality bit rates. Is there a problem with my RAM? Maybe I don't have enough?
Enumerate your system specs so everybody will have an idea.
Ow btw, don't forget to register your VDJ.
Whoa, i went through my system information and found that I only have 376 MB of RAM. WOW, I was very mistaken earlier. I'm thinking this may be my problem, correct? I'll need AT LEAST a gig.
Here's some more info to help diagnose this problem:
Microsoft Windows XP Home Edition
Intel Celeron CPU 1100 mHz
1.10 GHz, 376 MB RAM
Any idea how much this should cost me?
By the way, I REALLY appreciate all of the help and advice. You guys are awesome!
Low memory and Celeron processor - Not a good look... ;-)
You can increase your RAM but your running with an under powered processor - especially for real-time audio...
Time to upgrade my friend!!!
Cheers,
Roy
Gotcha. And remember, this is just for home use only. But I will consider the upgrade.
Do you have any recommendations for a new processer?
Thanks again everyone.
I have a screen resolution problem too.
I have a Dell XPS m1730 with a 17" screen.
When I open up Virtual DJ I get the same warning bubble as mentioned above saying I should have my resolution set to 1920 x 1200 pixels and the Virtual DJ and desktop reolution goes really huge and distrorted.
The problem is I do have my display set at that resolution.
Any ideas as to why Virtual DJ doesn't want to play ball with my laptop screen?
I run an XPS M1730 as well :)
I would advise against running any skin maximized, run it as a window instead. If you set your screen resolution to the same as the skin size it will fill the screen. If running maximized you will get issues minimizing the window. If you have to run maximized (for some crazy reason lol) then set your display size to the same as the skin and you shouldn't get the warning.
I use a custom 1920x1200 skin in window mode and it works fantastically.
Good stuff SBDJ. You may be asked a few questions from me while I get it all set up then ;-)
Hmmm when I open up Virtual DJ it immediately distorts the desktop resolution and the warning bubble comes up. When clicked it goes to the maximised screen which is a bit blurred. After that I can change it to window mode as you suggest but its a bit small on the screen and I can't make it any bigger.
This may be a general problem with my screen settings as some websites are a bit small. This one for example doesn't fit very well on the screen. Quite small writing in the middle of the page and large areas of black at either side.
I can use view>zoom + on my firefox settings but this doesn't apply for Virtual DJ. Is there a way I can permanantly change this in my control panel?
I am also having the problems with a latency spike that you have been having on that other thread but I'll write on that thread about it.
Not sure why you get the resolution warning box, but anyway.
The problem is the panel is happy running at 1920x1200 - whilst it will run at lower resolutions it won't look quite as crisp. Most VDJ skins aren't that high a resolution - thats why it has to resize, and why it looks small in window mode.
Best bet is to use a 1920x1200 skin in window mode.
Ok the internal mixer interface skin tries to maximise the screen straight away and everything gets messed up.
The new HE5 interface opens up to the window setting and doesn't distort. However the window is small in relation to the big screen.
Any idea how to change this?
Anyone know how I can change this window size without maximising the window?
Download the screen resizer program under the plugin section. Select the xml file of the skin you want to use and set the new screen size to 1900x1050. Always set the horizontal size lower than actual screen size. This will allow you to get full screen image in a windowed mode. As previsously stated, it is best to run VDJ in a window. Hope this helps.
Or get a skin that matches your screen resolution. Resizing a skin from 1024x768 to 1920x1200 will not be pretty!
I'm plannoing to buy a laptop only for mixing purposes it will have intel celeron processor 900 2.2ghz with 2 gigs of memory. do you believe that it will afford to perform djing and mixing?
wen i try 2 login 2 my virtual dj it says my screen resolution is low for the skin
wat do i do
You have two options:
1. Increase your screen resolution
or
2. Change your skin
hi i have a full hd 1080p and been having problem with my visrtual dj skin...not in any resolution appears well, just half of interface.....can anyone help me??
74%
