i have set a post in mac but no ans as yet.getting error when opening vdj skin 0% in xml.vdj wont open.anyone help please.jimmy normally does lol.and merry new year to ya all
geposted Wed 31 Dec 08 @ 7:06 am
I'm here mate, lol
Just try this, can you mate, Turn off or restart your PC and try and launch VirtualDJ again. I've had this problem a couple of times, and all I did was to restart my laptop.
geposted Wed 31 Dec 08 @ 7:11 am
hi my saviour lol.ive triedi will again but.is there a way of changing skin before opening.on windows i used to just change display size then open reset skin then reverse.ahhh mac hurting my head lol.jimmy u ever visit dublin you can come sort my crap out free digs lol
geposted Wed 31 Dec 08 @ 7:16 am
Hi
If this error persists it relates to corrupt registry and skin entries.
You should backup your cue points, databases ect from documents/virtualdj
You want to backup all of the XML files as this contains your personnel settings.
Then uninstall, then get a copy of the registry entry removal tool from the download section run this and reboot.
Then make a fresh install , replace your database and it should now be fine.
geposted Wed 31 Dec 08 @ 7:19 am
is there a registry entry for mac and 5.2.1 version
geposted Wed 31 Dec 08 @ 7:26 am
LMAO!!!!
No mate, but me and my girlfriends have always wanted to. Might take you up on the offer in the new year mate ;) lol
I think Simon may be right.
geposted Wed 31 Dec 08 @ 7:28 am
For mac you need to delete the preference library database.
Its located in HDD>Library > Preferences > com.atomixproductions.virtualdj.plist
This must be deleted, then drag the app to the trash and delete the VDJ folder in documents (backup the XMLS first!!)
Then install again this will give you a fresh start.
geposted Wed 31 Dec 08 @ 7:33 am
no bother jim mate.have a batchelor pad on standby lol.so i need a fresh download of vdj.also how does the reg tool work and is it for mac
ok downloaded ne version all seems to be grand rmx skin working.but the registry download is it for mac and how does it work,have software called error smart on my windows which i run everytime i turn on my windows works grand
geposted Wed 31 Dec 08 @ 7:48 am
No the registry download is for PC only.
geposted Wed 31 Dec 08 @ 10:03 am
Nice one mate. Would love dearly to sample a pint of Guiness, maybe a few, lol, in Dublin, I bet it's a awesome pint.
geposted Wed 31 Dec 08 @ 10:08 am
its real over here.pulled 3/4of the way set then topped up and you got a creamy pint of goodness(until the next morning lol).
geposted Wed 31 Dec 08 @ 11:09 am
