You should allow the DJ to give his MP3 that he's broadcasting his own name rather than the default VirtualDJ.mp3
i.e. http://ip.address.here:example/dj_rip_live_01-12-09.mp3
Also, you should have an option to select and copy the address to the clipboard so you dont have to shit there any retype it, see my post about that here:
http://www.virtualdj.com/forums/102910/Wishes_and_new_features/Allow_URL_to_be_copied_to_Clipboard_when_Broadcasting___.html
geposted Wed 14 Jan 09 @ 1:48 am
I'm not sure about this, but I think that you can send any link to somebody who wants to listen and it will work:
for example:
http://111.111.111.111:8000/YourDJName.mp3
Copying the link to the clipboard is a good idea.
for example:
geposted Fri 16 Jan 09 @ 11:57 am
Yes I think that's would be a good idea able to change VirtualDJ.mp3s name and info cos when you load it in Winamp it shows the name of the station as Virtual DJ and homepage as www.virtual.com and that wrong info...why is it like that anyway..come on update it so you can change it.
or is there another way of changing it..where is the virtual DJ.mp3 kept in what folder cos I can't find it in the virtual DJ folder in Program Files...Please Help...???????
I am using theVirtualDJ Trial at the moment..
geposted Fri 20 Apr 12 @ 7:48 am
